mpvi2 will not connect to editer... via bluetooth or cable. connects to the scanner with no issues (cable and bluetooth) on the same vehicle, uninstalled and reinstalled the suite with the same issue. resynced and nothing is seems to work.
Be sure you're disconnecting VCM Scanner first before you try to connect with VCM Editor.
We got this guy Not Sure, ...
I'm having the same exact issue. mpvi2 will not connect to editor. I took every little step you took like Bobby Brown... lol. No luck!
