Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Pressure transducers
    Mar 2020
    380
    I bought (2) 1/8 npt transducers to incorporate into my pro link. One is 100psi. One is 500psi. Both are advertised as 0-5v.
    How would you go about setting these up in the scanner?
    Jan 2014
    Australia
    1,981
    as long as u have the analogue inputs to use then u just need a 5v reference voltage then the offsets range for it to show the right pressure, same as setting a analogue wideband up
    Mar 2020
    380
    Currently I am using 1 analog for my WB, but I have been told that I can use it on my CAN wires and it operates the same. If thats the case, I will move it there, and then install 2 pin connectors on A1 and A2. Then I can exchange sensors as needed.
    Primarily I will use the 100psi for fuel pressure since Gen 3 doesnt report it, and use my 500psi for trans line pressure.
    Jan 2014
    Australia
    1,981
    yea if u can get the calibration scale from the manufacture ((volts/psi)+offset) thats all u have to enter in the ''transform'' function when u set it up
    Mar 2020
    380
    100 psi
    Input: 0-100 psi
    Output: 0.5V~4.5V linear voltage output. 0 psi outputs 0.5V, 50 psi outputs 2.5V, 100 psi outputs 4.5V.
    Accuracy: within 2% of reading (full scale).
    Thread: 1/8"-27 NPT
    Wiring Connector: Water sealed quick disconnect. Mating connector and wire harness (pigtail) is included.
    Wiring: Red for +5V; Black for ground; Blue for signal output.
    500 psi
    Input: 0-500 psi (Gauge Pressure)
    Output: 0.5-4.5V linear voltage output. 0 psi outputs 0.5V, 250 psi outputs 2.5V, and 500 psi outputs 4.5V.
    Accuracy: +/-1%FS
    Thread: 1/8" NPT
    Wiring: Red for +5V; Black for ground; Yellow (Green) for signal output
    Overload Capacity: 2-4 times of rated pressure
    Working Temperature: -40℃~+120℃
    Compensation Temperature: 0℃~+80℃
    Protection Class: IP67
    This is the info they supplied. Is anything else needed?
    Mar 2020
    380
    I hope to try this tomorrow
    Jan 2014
    Australia
    1,981
    ok for the hpt scanner inputs
    the 0-100psi transform will be (input / 0.0400) + -12.5
    the 0-500psi transform will be (input / 0.008 ) + -62.5
    Sep 2002
    Chicago, IL
    6,395
    Who makes the sensors?
    We got this guy Not Sure, ...
    Mar 2020
    380
    MNJWS off of Amazon
    Nov 2017
    1,464
    What are you using for the 5v supply?
    Mar 2020
    380
    12v to 5v DC converter
    Sep 2002
    Chicago, IL
    6,395
    Can you provide a link to the sensors? I was unable to find them.
    Nov 2006
    2,741
    Quote Originally Posted by village_idiot View Post
    100 psi
    Input: 0-100 psi
    Thread: 1/8"-27 NPT
    500 psi
    Accuracy: +/-1%FS
    Thread: 1/8" NPT
    I can do this if you need.. but if you google search y=mx+b calculator or something like that you should be able to find a site you can input x and y values and get a linear function.
    Tuner at PCMofnc.com
    Nov 2017
    1,464
    You can also graph it in excel and it will give you the formula for the line.
    Mar 2020
    380
    Alvin is the values 07GTS posted above not correct?
    On the trial run of setting this all up, I will run a T fitting or whatever is necessary to hook a mechanical gauge in as well on the first few to verify they are scaled correctly
    Nov 2017
    1,464
    07GTS's formulas look right to me.
    Nov 2006
    2,741
    You can easily check yourself..
    plug the x's in and see if it gives you your Y's.
    so .5v = 0 psi
    2.5v = 50psi
    4.5 = 100 psi
    Mar 2020
    380
    Good point
