Hello. I would like to increase the speed of engaging reverse gear. In HP I only found "Clutch B" boost pressure and "Clutch B" boost pressure time. (Clutch B = Direct). I can't find settings directly for reverse gear. In this situation should I only increase Clutch B boost pressure and boost pressure time? Direct is engaging in reverse gear in 6R60.
Best regards.
