I do not have cruise control with SRC
I have a 1999 Pontiac Grand Prix GTP
I have a fully built transmission from INTENSE & I use a Speedometer Recalibration Controller (SRC) & custom reluctor wheel to compensate for the gearing.
I have loss the use of my cruise control since the installation of the Speedometer Recalibration Controller (SRC) if I disconnect it then everything works fine but then my speedometer will be off alot, I even tried using the ZZP mini SRC & the outcome is the same, either way I lose my cruise control & I want it back.
F.Y.I I have a 1" GM racing chain that is 3.52 gearing (its an option only with the GM chain)
I also have a custom reluctor wheel for use with the 3.52 gears.
I want to know if there is a way to change any of the settings (most likely the VSS pulse per mile) to fix the problem.
If you have HPTuners then yes you can recalibrate your gearing and tiresize(and scale/adjust your shift tables to be right) and get your speedo squared away.
FWIW, I tuned my friends 98 cavalier with low-pro tires on it and his cruise ctrl still worked afterwards.
