Hey everyone,
I've been digging around the forum for the last couple days, but I can't find exactly what I'm after. I just need to know how to take the info on my cam spec sheet and turn that into info I can punch into HP Tuners. I'm trying to understand the process of taking the specs, converting them into usable numbers that I can punch into HP Tuners and get going. Any help is appreciated!
Here's the cam card:
Here is the section in HP Tuners that I'm referring to (From my stock read. Car was originally a 6.4):
Here's my mod list:
My car: 2018 Dodge Challenger T/A 392
Transmission: Manual
- Clutch McLeod RTX twin disc PART # 6344907M (1000 HP)
Intake: Corsa Closed Box Air Intake W/Power Core Filter (PN 468646)
Throttle body: Stock 6.4L / 392 throttle body
Spark Plugs: NGK LZTR7AIX-13 (5107) Iridium (1 step colder)
Custom Grind Camshaft
- Specs (See Picture Above)
- MMX Cam Phase Limiter (PN CAM-5761)
- PSI 1516 ML Beehive Springs
- Trend .105 Wall CNC Premium Pushrods
- Hellcat non-MDS lifters
411 Stroker Kit by MMX
- Forged Mahle 2618 Pistons, 4.090 Bore, inverted dome design, grafal Anti-friction coating on skirts
- 1mm 1mm, 2mm Stainless steel rings w/napier 2nd ring
- Forged Molnar 3.900 Stroke Crankshaft
- Forged Molnar 6.25 Connecting Rods w/ 7/16 ARP bolts
- .200" Wall H13 DLC Tool Steel Wrist Pin Upgrade
- Coated Rod Bearings
- Premium Main Bearings
ARP Head Studs
Cometic MLX 5 Layer Head Gasket
- .054 Thickness
Oil Squirter Blockoff Plugs
160* thermostat
American Racing Headers - Long tubes
- 2" Primaries to 3" collector
- Catless connection pipes
Fore Innovations L2 Fuel system (dual Pump)
- Regulator set to 55psi currently (please let me know if you'd like this set to a different value)
- Dual Walbro 525LPH Fuel Pumps
- -8 PTFE Feed and return lines
- FC2 controller
- Microglass Filter Media
Deutchwerks 95lb Injectors PN 17U-00-0095-8
Gen 5 Whipple 3.0L
- Whipple fuel rails
- Whipple air-to-water intercooler
AEM Series X Wideband O2 Sensor & Gauge (PN 30-0334)
Oil Cooler
Barton Shifter Assembly
Compression with 411 Kit & .054 Head gasket should be approx. 9.5:1 (Per MMX)
Thank you.
