Results 1 to 9 of 9
Thread: Throttle closes at 7k rpm, 2014 Coyote with Roush Strategy
    May 2015
    2
    Anyone take a look at the tune and datalog to help troubleshoot 7k throttle reduction from WOT? Runs pretty good otherwise, but haven't been able to find the limiter here.
    Mar 2022
    Indiana
    2,951
    Upload a better log with more PID's. Attach file in .hpl format.
    Feb 2017
    TX
    761
    Man you're going to blow that motor. The second pull never goes into PE and you're going all out to 7600 at idle lambda.
    Change your PE throttle threshold. Lower the first cell to 70% throttle and curve it down to 30% at 6500.
    What are your mods? What throttle body do you have?
    You're hitting a torque limiter, Torque Management > General > ETC Torque Max needs increased. Also in the same tab, set the oscillation switch to disabled.
    May 2015
    2
    Thanks for pointing out the PE and Torque limits. I'll make the changes and re-log with the PIDs from Sirius and respond back. This is a 2.9 whipple rear feed with VMP Twin Jet 67mm TB.
    Nov 2009
    All Around
    3,149
    post manual roush stock cal
    you cant have your driver demand like that
    This may not be the case here, but I have seen instances where with the Flex Fuel logic disabled, it will still reference the FFV Wot Lambda table, so just as a precaution copy over your non FFV Wot Lambda values.
    Oct 2016
    Poland
    1,744
    Quote Originally Posted by SultanHassanMasTuning View Post
    Believe or not this trick actually works quite good...
    as for the limiter:
    Nov 2009
    All Around
    3,149
    torque limits yes, driver demand no it may drop you out of PE
    Oct 2016
    Poland
    1,744
    I cant agree on this one sorry.
