Results 1 to 2 of 2
Thread: Help. Auto to Manual. what is the correct procedure?
    Jun 2010
    293
    Attached is the file of the car, it is a 2014 jeep with hellcat engine.
    its setup with a 4l80e trans now.
    What would be the best aproach here?
    Do i need to changue in the tune for manual trans? is that even posible??
    Or i need to flash a manual file with hp tuners?
    any help would be apreciated
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    So the short answer is, No there is no procedure, but a few things you can do, 1, Engine>General> where you have 3.6L listed as displacement change that to 0, 2nd in your TCM flip the Manual switch, sometime that will keep it from tripping the TCM 0700 code(been a while might have that # wrong.
    Since you are running a 4l80, is it throwing CEL code for Transmission communication ?
    I ran both of my 2014 rams with the Auto File when I had the 727, in the "fast truck" and the RH46RH. then T56 then Lenco in the "no it's stock" truck.
    Same with my Nephew's 09 and my Niece's 14 Rams.
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
