2018 Charger Twin Turbo Idle Oscillation
Battling very bad idle oscillation in a twin turbo Charger and unsure how to combat it. Could use some advice. It has a 426 stroker, stock throttle body and intake manifold, twin turbo with fore fuel system on e85. I'm attempting to help out a buddy so I don't know much more than that. I ran some logs and posted the tune as read.
Charger TT Idle drive.hpl
Charger TT Idle.hpl
2018 Charger TT Read.hpt
Maybe too much throttle action at zero volts. Try a smaller startup adder at zero volts. Yours is currently .9 or something I would make take small steps maybe .05 every time until it settles down... if that works.
2018 Charger TT Read IDLE.hpt
give this a test
you cant have all idle parameters the same and also your minimum timing higher than PT
