Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: 08 Silverado Truck Norris cam
    Tuner in Training blackbeauty435's Avatar
    Sep 2022
    Saint George, UT
    22
    New to the forum, new to tuning
    Original tune dome through Mail Order Tuner, it was running fine and now i'm having issues.
    Only thing I changed was upping the idle
    New 5.3L
    No DOD or VVT
    Stock heads with BTR .560 Beehive springs
    AFE CAI
    Jet Pro Flow 87mm
    Hooker Blackheart 1 3/4 shorty headers
    Seems to be misfiring a lot, mostly at idle
    I thought that it may be my plug wires, which it may still might be. Ive replaced the wires and checked the plugs and the plugs looked good
    When they resent me the tune file, it seemed to me like it was incomplete
    Attached is the tune file and recent datalog
    Maybe someone can tell me what I,m missing or need to change
    Thanks in advance!
    Nov 2006
    2,742
    uggh.
    The VVE stuff needs to be tuned. It will make a huge difference in how smooth the truck runs.
    The tuner should have maxed out the misfire tables. Misfire diag just doesn't work with a cam. It picks up on the lope as a miss.
    The fuel trims are a bit lean too. A solid go over on the tune should make a big difference.
    Tuner at PCMofnc.com
    Sep 2022
    Saint George, UT
    22
    Sent that file and data log to my tuner
    He sent me this in return
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    195
    Quote Originally Posted by blackbeauty435 View Post
    Ouch on the spark table. Looks like 20 deg locked out and send it. Get the VVE tuned also
    Western New York's Performance Headquarters
    716.830.0506
    Sep 2022
    Saint George, UT
    22
    Yeah I?ll have to do another data log
    Truck has no power now
    I?ll also add that they need to look at the VVE as well
    Mar 2020
    380
    16deg idle timing is pretty low for that cam. Mine usually end up in the 18-22deg range
    8g/s idle airflow is probably pretty low also
    All of the misfire tables need maxed out, and PO300 code needs removed
    Your Startup Airflow is pretty low. Does it have an extended/slow crank?
    Your COT over temp is off, and one table for catalyst spark is off... If you do not have cats, all the rest of the cat spark tables need zero'd out, and the corresponding DTC's set to no error for cats and rear o2's
    Your main spark table is a mess
    That's at a quick glance
    Sep 2022
    Saint George, UT
    22
    Yes it does have an extended slow crank, and when it warms up it barely cranks
    Yeah, I'm thinking at this point I may try a different tuner
    I'm just not getting results from MOT
    Seems like it's running worse with the updated tune
    I did a good long data log today and it actually stalled out while turning a corner
    I let them know this in my most recent upload to them
    Tuner in Training BackWoodsBandit's Avatar
    Mar 2022
    12
    I’m by no means a tuner, been dealing with trying to fix the tune on my 6.2 that mot did, actually took it to him, anyway, if you haven’t already spend the money and get some good wires with ceramic boots, the headers will ruin plug wires, even with heat sleeves….mine did anyways
    Aug 2021
    847
    New 5.3L
    No DOD or VVT
    AFE CAI
    Jet Pro Flow 87mm
    Thanks in advance!
    I want to start out by saying I am no tuner by any means. However, I did find your issue. It is underlined and in bold letters. ^^ That guy is just taking peoples money. It's a disservice to the end user and a slap in the face to the actual tuners who so willingly help out on this forum. Knowing now what I didn't know when I was just getting started, I'd be more than willing to pay one of these more knowledgeable guys on here for a tune. Good luck with your results.
    Sep 2022
    Saint George, UT
    22
    I hear that. I payed him a lot of money and I'm not happy with the way it turned out
    So, my question is, where do I go to add grams to my idle airflow?
    Aug 2021
    847
    i hear that. I payed him a lot of money and i'm not happy with the way it turned out
    so, my question is, where do i go to add grams to my idle airflow?
    engine>idle>airflow>base running airflow>airflow final minimum
    Sep 2022
    Saint George, UT
    22
    That?s what I changed, still showing 8gs at idle
    Maybe I did it wrong
    Sep 2022
    Saint George, UT
    22
    This what he has me set at currently
    So, should I start high at the low end with ending value at idle being 10g or so to begin with and smooth from idle
    again, sorry I am new to this
    Sep 2022
    Saint George, UT
    22
    This my current startup airflow
    I changed my final airflow minimum but it's still showing 8g's at idle
    Do I need to bump up the values in this table?
    Jan 2019
    Australia
    81
    Give this a try. You will still need to dial in your fueling but it should be much better.
    Cheers.
    Mar 2020
    380
    Ill have some spare time this morning to help you with a decent base file. Will post one for you to start logging from shortly
    Mar 2020
    380
    silverado Retune help.hpt
    Main Spark wise, I just blended in the big dip they left in the middle. This is set in MAF only mode. Starting on that side of things will get fuel dialed in the quickest and more drivable quicker. Once fuel is perfect on the MAF, you can move on to the VVE table and blend it like OE does. This file should at least crank up better, and I doubt it will die on rolling turns/stops while off throttle. Use it as a compare file if you want to see the cranking air, BRAF, and idle spark differences.
    After a few logs, we can see if this is close idle wise and work on your MAF fuel table
    Sep 2022
    Saint George, UT
    22
    You guys are awesome! I appreciate you!
    Not sure I'll be able to flash tonight, it's our busy season and I'm working 12-14 hr shifts right now.
    Sep 2022
    Saint George, UT
    22
    Here's the latest data log
    Sorry for the delay
    Sep 2022
    Saint George, UT
    22
    Updated data log with wideband
