Results 1 to 6 of 6
Thread: TCC Disable in 1st -4th gears
    Oct 2019
    6
    Hi Everyone
    I want to make my first tune for my 2015 Sierra 5.3. I am planning on disabling the convertor lockup in 1st thru 4th gears. I am making the changes in Normal and Pattern A (tow/haul) Pattern B is already set disabled.
    My question is: I am safe to assume I need to make the changes in the hot Trans section as well?
    thanks
    Oct 2019
    6
    Quote Originally Posted by Berkley View Post
    Hi Everyone
    thanks
    Or maybe it doesn't matter in hot trans if normal and both patterns are disabled....
    13,559
    I only do the normal table. Never touched the pattern a or b etc etc etc.
    Oct 2019
    6
    I found from a different source that the Hot Trans field should not be disabled. Locking up the TC would help cool down the trans if indeed it gets to the Hot trans parameters.
    Nov 2006
    2,700
    I wouldn't treat the hot trans table like a situation you get into normally. That is like the trans is super hot.. I want to say like 260 degrees or something.
    Tuner at PCMofnc.com
    under Torque managment tab... got to Torque reduction tab, disable everything in the boxes except for Neutral Down skip, and set Speed Control Terminate to Immediate.
    then follow this guys set up for the tcc
    https://www.youtube.com/watch?v=KPyW_mcyNC0
    enjoy : )
