mvpi 3 pro link aem wb issues
just got the mpvi3 and pro link wired in to a new aem x series wb and using the the transform eq ratio 30-03x0 math i am getting a reading of .53. i fooled around with some user defined and was able to get it close to the wb read out on the gauge at idle but it would not change as the afr was richened up. it would jump around from .97 to .99 or so but when gauge read .88 scanner read the same .97-.99.
*for whatever reason the scanner just takes some time to start reading correctly, drove the car for a short while and it was showing the correct reading. it seems to be working fine.* -----correction it worked once-----
