Immobilizer VATS security problem
Ok, I did a complete re-flash on a 2005 GTO computer with a Tech II. Afterwards, I couldn't re-link the PIM to the VCM (I was able to do the BCM to PIM). Apparently, only dealerships can do the VCM to PIM re-linking. Needless to say, the car wouldn't start.
Anyway...
I tried to re-link through HP, but it did not work. I downloaded the program and shut off all of the VATS (1&2) and all of the VATS and Immobilizer codes came up (P0513, P0633, P1629 & P1632). I turned those off and I still get a "Service Vehicle Soon" and the wrench in the display when started (it does at least start now)!! How do I re-link all of the computers so I can turn the VATS back on and all of the codes???
Please help,
Mike
HP Tuners Owner
the GTO had an early TSB with a immobilizer issue that required the PIM to actually be replaced i think. Regardless the PIM cannot be linked with our software.
I couldn't find anything on a TSB for the PIM. How do you install a new computer with a completely new re-flash (say from a different VIN) in the GTO? Is there a way for me to do any kind of a re-link with the computer?
Thanks,
Mike
HP Tuners Owner
I'll have to look into it, possibly something has changed since we tested this. For now you will probably need to go to a dealer or relink it with tech2/SPS.
