Results 1 to 13 of 13
Thread: MAFless LSJ tune
    MAFless LSJ tune
    Has anyone tried a MAFless SD tune on the LSJ yet?
    Is it possible?
    2000 Grand Prix GTP 11.586 @ 118.20
    Best MPH: 121.72
    New Ride: 04 GTO no times or anything yet
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    yeah it should work just fine http://www.thetuningdoctor.com/HPTun...uningGuide.doc try this guide out and tell me how it works
    Jul 2006
    Manchester, New Hampshire
    314
    I've been running in SD since I got HPtuners mostly lol. yes it's possible. And the only thing that I have seen NOT work is disabling Dfco, I still lean out a bit when letting off throttle. Just set maf fail hz to 0. Good luck
    06 Cobalt SS SC
    2.7 pulley
    42.5lb Injectors
    HPT VCM Suite tuned
    Custom SRI
    Tuned
    13.701 @ 103 Mph
    Best 1/4 mile Stock
    14.295 @ 102 Mph
    02 TURBO Cavy 2200
    Finished
    Times coming soon
    Jul 2006
    314
    Man seconds faster then me submitting foff :P
    06 Cobalt SS SC
    2.7 pulley
    42.5lb Injectors
    HPT VCM Suite tuned
    Custom SRI
    Tuned
    13.701 @ 103 Mph
    Best 1/4 mile Stock
    14.295 @ 102 Mph
    02 TURBO Cavy 2200
    Finished
    Times coming soon
    Thanks, I may give this a try on my buddies ION.
    Best MPH: 121.72
    Sep 2006
    31
    Quote Originally Posted by John_F
    Set MAF fail to 0, then disable the P0068 code (it causes limp mode when the MAF fail is reached)
    The only drivability thing is, it will kill cruise control for good.
    Jul 2006
    314
    ^ this I find is wrong I run SD and still have cruise control, I know I'm in SD since 0101 2 and 3 are on at first error. I know cruise control shouldn't work since it supposed to use the Maf table but some reason my cruise control works while in SD
    06 Cobalt SS SC
    2.7 pulley
    42.5lb Injectors
    HPT VCM Suite tuned
    Custom SRI
    Tuned
    13.701 @ 103 Mph
    Best 1/4 mile Stock
    14.295 @ 102 Mph
    02 TURBO Cavy 2200
    Finished
    Times coming soon
    Apr 2003
    Almost 2000 feet.
    7,876
    Minimum PW is probably a little low there or the offset table is too low there. Just log Manifold Vacuum and Battery Voltage and create a histogram like your Offset table and log away....
    Always Support Our Troops!
    Jun 2006
    Pitt Meadows, BC
    58
    lol...hun?
    Apr 2003
    Almost 2000 feet.
    7,876
    You can create a PID (custom). Just take 100 - MAP to get Vac. It's close enough for government work... LOL
    Apr 2003
    Almost 2000 feet.
    7,876
    I would make 2 histograms:
    1 with AFR Error/STFT/LTFT (a fuel trim term)
    1 with Injector PW (3 decimals)
    Then compare the two and watch your PW as well. If you get below 1.14 msec the Mototrons can/will misfire as there's not enough time to open & close the injector. Then just drag down the Offset values (min PW & Default PW as well.) until you get the fueling "back to normal"
    I usually have a VE histogram with the same fuel trim info in it as a reference as well.
    Apr 2006
    No where in particular
    65
    /\ I wonder if this may have something to do with MY little misfire issue... http://www.hptuners.com/forum/showthread.php?t=11083
    04 Ion Red Line - Black "Stealth Beauty"
    Apr 2003
    Almost 2000 feet.
    7,876
    LOL Siemens makes the Mototrons...
