Results 1 to 5 of 5
Thread: Would anyone be willing to help me adjust my Maggie Tune for 2016 Camaro SS?
    Nov 2022
    LAS VEGAS
    3
    Hey everyone,
    I hope everyone had an amazing Thanksgiving! I am in the process of teaching myself still but I am wondering if anyone could take a look at my tune received from Magnuson. I know its a bare minimum tune but the car is lacking power/sluggish in the mid RPM range. I don't believe Magnuson set my tune up for the ROTO CAI. Also, ever since I installed the recommended LT4 spark plugs, its been driving very rich it seems like. I have the OEM tune and log files if needed. Thank You
    2016 Camaro SS
    Mag 2650
    20/10+11 (wheels)
    ROTO FAB CAI
    LT4 spark plugs
    Nov 2006
    2,742
    Any good email tuner should be able to get you going.
    I would encourage you into adding a SCIAP sensor. It will make the car drive much smoother with that type of blower.
    Tuner at PCMofnc.com
    I second the Sciap sensor Addition.
    However,
    I worked on my Camaro Maggie setup with the NA-TIAP setup for a while.
    I Have a tune i can send you (on request) that should address the deltas with the LT4 Plugs, and a closer VVE/VVT table.
    (with this i was able to manage 580rwhp and an easy 26 mpg on 6psi)
    I assume the ROTO CAI will require a MAF re calibration additionally.
    There are a ton of good resources for this, I recommend 'goat rope garage' youtube channel
    The Tune from Magnuson was a bare minimum at most, and I only recommend it to get you running without a big delay.
    If you don't already, you need to get a Wideband hooked up.
    Nov 2022
    LAS VEGAS
    3
    I will look into getting the SCIAP asap and your tune would be amazing. I appreciate the help guys!
