09 silverado running lean possible spark knock, I'm seeing on gen3 vcm editor there's a way to change calculated Map min/max when the Map is out of range but not for gen4. I tried searching through the forum and haven't seen anything relevant.
You often just have to disable it with the temperature / airflow qualifiers.
Tuner at PCMofnc.com
Disabled it. Thanks
On a gen4 I can't locate this table.
Its not a table on those. Usually its airflow limits.. labeled something like P0068/P0106
Wonder what would happen if you hit 'CTRL+N' then typed in 'p0068'/'p0106'? (spoiler: magic, that's what)
