Could someone advise what would cause this. I replaced my harness and maf as the stock one went out but now i have a new issue while trying to re-tune the c5z06 5pin MAF. I initially got the P0106 so i raised barometric Error MAP Calculated Max +20% and minus -20%. This removed the code but did not stop the ltft from being stuck at -3.9. Car idles and drives fine. WB is showing to be getting in line with the maf but my stft are around 20% rich and I can smell gas. Looks like the system is ignoring the fact that I lowered the high rpm disable to 400 to run off the maf so i could tune the table. Put new 02 sensors in no change. I don't see any leaks anywhere and sprayed starter fluid to see if a leak would detect but nothing which makes me think something else is going on. Any ideas are much appreciated. PCM also updated to a 02 one so i really did not see how i could have been out of range on the maf.
