I am working to solve vvt cam issue after swap comp cams 54-454-11 in LMG 5.3 2011 E38 deleted code p0010,p0011,p3400,p0345, camshaft: None but still start hard like 500 rpm .
That is a NON VVT cam... I'm sure if that's what you are stating in the post.
So I assume you replaced the front cover, timing components, etc to the NON VVT stuff , Right???
yes, I replaced everything to delete vvt cam, before 5 months when I start up the engine everything is good, but yesterday after changing simple something like airflow final minimum increase of 10% I got a check engine light and traction control light at the same time,
