Results 1 to 9 of 9
Thread: LS3 with TVS2300 SD Tuning
    May 2022
    14
    Hello, I have a stutter/stumble on moderate acceleration with my speed density tune. It is visible in the RPM graph in the attached log. I see that the EQ ratio is a little lean in spots, but before I go increase fuel, I am hoping someone can help identify the cause of the stumble or confirm it is from the lean condition. I appreciate the help.
    60percent_throttle.hpl
    my ss n/a stumbles in sd mode after the cam so i stay in open loop maf and my wife is even happy with how it runs
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,454
    Something looks wrong with your timing--airmass doesn't look right.. Go to Airflow---Dynamic and make disable 8000rpm and reenable 7900rpm.
    I would make P0101,102,103 all MIL on first error to fail the MAF
    Go to Engine Diagnostics --Airflow-- MAF fail 2 (not 2,000) and enable 1, not 1,000
    Are you sure you have a 3 bar GM Map sensor?
    2013 Silverado 5.3, 6L80k 8.8
    Nov 2006
    2,683
    It feels odd there because you are making significant boost without being into PE. You need to work on your PE enable settings.
    It's far to lean there.. To the point where you might can hurt something.
    Tuner at PCMofnc.com
    Oct 2022
    St. Petersburg, FL
    70
    Like the guy above me mentioned, you need to get this thing into PE MUCH sooner before you hurt this thing, and the stumble is because its lean as shit at 4-5 lbs of boost.
    I would also change how you are failing the maf as the car will cold start much better and fail the MAF much quicker as well. Set the MAF fail high to 1, lower all of the tests right below it and set your dynamic to something like 8,000/7999
    Mike Carnahan & Branden Leeb
    Founders/Owners Elite Tuned School
    Visit the Elite Tuned website to build your custom calibration.
    Visit The Elite Tuned School to unleash the secrets of the tuning world.
    We would love to connect with you on Instagram & Facebook.
    May 2022
    14
    Thank you all for the responses. PE was the issue, I guess the baseline tune PE settings needed some help. I tried a few changes to the PE throttle table, but that didn't seem consistent so I used the ZL1 PE parameters and those seem to be working well. Log attached.
    60percent_throttle_2.hpl
    May 2022
    14
    Yesterday, with the SD only tune, I felt a stumble under normal driving with no throttle variation. I would appreciate some guidance on where I to look.
    Attachment 126513
    Attachment 126516
    Attachment 126514
    Nov 2006
    2,683
    Cannot tell much by the short logs.
    This might be just normal tuning issues. Have you considered hiring a tuner?
    May 2022
    14
    Complete log is attached.Attachment 126518
