Results 1 to 7 of 7
Thread: Tahoe 2008 disable ABS and Traction Lights
    Dec 2022
    Question Tahoe 2008 disable ABS and Traction Lights
    Hello ,
    I'm new on Hptuners , i have Tahoe 5.3 2008 and cancelled the ABS and the 4x4 Trans and looking for Disabling the ABS and Traction Lights , is this something to be done under Engine Diag or Trans Diag and which DTCs to be tackled, your help will be much appreciated.
    13,565
    Not something done with HP Tuners.
    Dec 2022
    Thanks for the feedback Sir, may i request more elaboration on the provided picture.
    7,624
    The BCM is requesting ABS/Trac light on because the ABS module has been removed and is no longer able to send messages to the BCM, and HP Tuners does not read or write anything inside either of those modules. It's powertrain-only.
    SoCal
    1,562
    Desoldering iron. Re install cluster
    how to disassemble for the new guy.
    https://youtu.be/xwwT_b9kaGU
    7,624
    Swatch of electrical tape?
    There were rumors back in the day that the used car lot guys would turn out warning lights using a red-hot scribe, melted through the face of the cluster to poke the bulb out. Though I never saw evidence of that having happened myself.
