Results 1 to 9 of 9
Thread: Cannot Add/Use AEM X-Series OBDII Wideband Channel in Scanner
    Aug 2020
    12
    Murphy's Law rears its ugly head again.
    I bought my 30-0334 X-Series OBDII Wideband Gauge from HPT in August and worked fine and logged numerous pulls in HP Tuners VCM Suite until... two weeks ago!
    Now, I open channel selector and tap the "Broadcast Channels" icon, the correct channel (I believe), External Inputs > AEM > X-Series UEGO (30-03xx) "AEM channel 12 WB EQ Ratio 1", is highlighted in blue.
    When I double click it, it's added to my channel list, but it's greyed out and a broken link icon shows up, whereas all the others have polling channel icons. (See attached)
    If I then click Start Scan", the AEM channel is removed (?)
    Help! I can't be the only such unfortunate HPT user.
    The car is a 2020 ZL1.
    7,635
    It's not an External Input, it is its own controller on the network.
    Aug 2020
    12
    Would you snip and post an image showing where it's located on the channel selector? Thanks
    Here's what my channel selector looks like:
    Aug 2020
    12
    Typing OBD or controller finds nothing relevant. Typing WB only finds the attached under external devices. And I only see 0x7E0 thru E3
    7,635
    may have to change the ecu address or pid address in the WB as hpt wont recognize all options, try different pid numbers first
    Quote Originally Posted by 10_SS View Post
    Dont choose it from External Inputs.. it's not using those. It's using a CAN address, just like the other GM OBD modules
    Aug 2020
    12
    1. Delete contents of folder, HP Tuners\VCM Scanner\Vehicles
    2. Download current HPT Suite (or Beta) and MVPI drivers,
    3. Connect the laptop to OBDII,
    4. Put the car in service mode, WB should power on,
    5. Wait 20 sec. for WB sensor to warm up,
    6. Select mode "obd2" on the AEM gauge,
    7. Close HPT Editor and open Scanner.
    8. Click "connect to vehicle" in scanner,
    9. Vehicle>Repoll vehicle parameters,
    10. Click gear icon with green + "add channel"
    11. [add new channel] dbl click "WB EQ Ratio 1 SAE " under OBD2 [I don't remember the entire channel tree]. Do not click any External Inputs.
    12. Click "Start Scan", the WB channel should remain in list and display active scan data.
    13. Push ignition button to exit service mode.
    14. Start engine, start scan, and the WB channel should display active scan data.
    Jan 2023
    1
    Hi.
    I have almoast the same problem, but i use Pro link+ and cant read anything from can 1.
    i have AEM X-Series UEGO 30-0300 whit Bosch LSU4.9
    Wires i have used is :
    AEM Pro Link+
    Red - Switched 12V -
    Black - Ground - Black
    Green/black - CANL - Yellow
    White/black - CANH - Orange
    White - 0-5v - Red
