Results 1 to 3 of 3
Thread: is tune this safe to drive on ?? logs attached
    Nov 2022
    6
    lq9 , 6.0, 799 heads, summit stage 2 8707 cam, full length headers, tbss intake, 36# injectors, 3200 stall , 4l80e, 93 octane, dbw, MAF, i installed an AEM AFR that is not yet connected to pcm, will use egr input, only driving to gas station at under 1/2 throttle on these logs, afr read 13.9- 14-8 on the whole trip. hoping its safe to drive on and start to work on tune. Thanks for any help and suggestions in advance
    Sep 2021
    470
    Get it into OL SD and start with the wideband. It would be easier to set your pe eq ratio to one value, 1.17 or 1.2. Set pe ramp in to 1 and enable torque from 100% to something lower. As long as your injector data is correct it should be fine to start with what you have.
    Nov 2022
    6
    thank you for info
