Results 1 to 4 of 4
Thread: Main spark table select speed?
    Nov 2014
    Utah
    60
    What does this feature do? If I'm understanding this correctly, above 4 mph the high and low octane spark tables are disabled? Is the description correct? What does it use if it doesn't use these tables?
    Dec 2019
    MS
    567
    Not exactly sure which one your talking about but if im correct, the one your questioning is the MPH at which it switchs between idle spark and running spark.
    EDIT: I see 2610 at the bottom.. Dont worry about adjusting that.
    Nov 2006
    2,742
    Above that speed it will not go back to the idle spark tables when throttle is below threshold defined right next to that setting. (pretty close to 0%)
    Tuner at PCMofnc.com
    Nov 2014
    Utah
    60
    Thanks, I get it now.
