Results 1 to 17 of 17
Thread: E38 ECU trans question
    Dec 2022
    4
    HI
    i have a 2012 5.3 Gen4 RPO LMG engine and 4L60E 17pin transmission
    with a E38 ECU do you need to use a TCU computer or does it run the trans by itself?
    if the E38 will run it by itself what year do i need to get?
    thanks
    405
    2,326
    A 2014 5.3 should be a DI engine. An E38 won't run that.
    7,646
    2014 Express van 5.3 was still port injected, neener neener!
    But, this is why specifying your parts by "E38" or any other ECM type is nearly meaningless. E38 has 4 or 5 different service numbers, meaning, the board-level hardware inside is different and they can't interchange. YEAR/MAKE/MODEL (and engine RPO is nice to include, too). Basics, people. Come on.
    Dec 2022
    4
    sorry new to this its a
    2012 5.3 Gen4 RPO LMG engine and 4L60E 17pin transmission the trans is not original to the YUKON SLT the engine came from
    7,646
    You already have the ECM?
    ALL T42 TCMs interchange hardware-wise, but not all T42 OSes will work with all ECMs. I believe the only breakpoint is pre-'09 and post-'09. Something about the comm protocol changed there, and early won't talk to late and vice versa.
    T42 service numbers:
    24234503
    24223112
    24226863
    24230461
    24235340
    24235776
    24239224
    24239427
    24242391
    24243901
    24251062
    24252114
    So if you were to go to ebay and search for one of those numbers plus 'programmed to your VIN' and gave the seller 1GCNKPEA9BF140932 (which is a 2011 Silverado 4L60E), that would get you a compatible TCM.
    Dec 2022
    4
    i just dont know what the trans is out of let me see if i can get the numbers off it
    7,646
    I don't think anything but 17-pin units were in use as of 2011. Some platforms got the change earlier than others but that started in like '07-'08.
    Dec 2022
    4
    someone painted over the sticker but this is what i found behind the tail section
    7PKD166J 43655156
    i was able to clean the sticker
    7PKD 24230158 TOLEDO 617PKDY43655156
    thanks
    7,646
    Any 17-pin 4L60E will work with any 2009-up or whatever TCM. I'm unsure of the exact breakpoint but you couldn't use a TCM OS old enough to not work with the trans, because an OS that old wouldn't work with the ECM you already have because of the change in comm protocol. Get it?
    Mar 2020
    380
    You need to get an ECM from an 07/08 model Silverado/Tahoe/Etc that came with a 58x Engine and a 4L60 trans. License credits for that, make sure your injector data/MAP data matches your engine, and start tuning
    7,646
    Wouldn't it be easier to keep the existing ECM and get/program a TCM to match, especially since the stock TCM calibration from a 2011-2012 anything will work out of the box with a late 17-pin transmission? '07-'08 Silverado was all 15-pin, for both 4L60E and 4L70E.
    Jan 2014
    SoCal
    1,562
    Cost for a built 6L80E is pretty pricey in my neck of the woods right now. Even wrecking yard stuff is pricey. I'm with you though. More gears, more better.
    Jan 2014
    SoCal
    1,562
    Found a decent guide for the 4L60 but I don't see your broadcast code.
    https://cpt4l60e.com/4l60e-case-identification-diagram/
    7,646
    T42/4L60E(/65E/70E) was used up thru 2014. Nothing 'bout T43 stuff here. Any ECM OS from the post-comms-change breakpoint (mid 2009 or something?) will talk to any post-comms-change TCM, whether it's T42 or T43. Or so I have been told, that the ECM OS is no different whether it was originally built as a 6 speed or 4 speed.
    1GCNKPEA9BF140932 is a 4.8L/4-speed 2011 Silverado. That TCM OS would work just fine with the ECM from a 2012 6-speed Yukon. Allegedly.
    7,646
    2011 Express 6-speed/T43, ECM OS 12639835
    2011 Express 1GCWGFCA5B1134609 4.8 1303581293.hpt
    2011 Silverado 4-speed/T42, ECM OS 12639835 (same as above)
    2011 Silverado 1GCNKPEA9BF140932 4.8 E38 (4L60E T42 24252956) 1346009422.hpt
    Jan 2014
    SoCal
    1,562
    You're right. When I saw LMG I incorrectly thought they all had T43's
    7,646
    If it's a swap vehicle with none of the factory integration crap I don't think it matters if you mix and match platforms for ECM & TCM. Not a swap would probably have issues, like PRNDL display, tow/haul etc.
