Results 1 to 7 of 7
Thread: 2013 ford escape not hitting desired load at WOT
    Feb 2018
    824
    Relatively new to ecoboost tuning and I cannot for the life of me find out what is limiting me from hitting the desired load at WOT. I've messed with the tq tables slightly to increase the desired load, but once I go WOT the actual load just starts tapering back down under 2.0. Any insight would be appreciated. Thanks
    SPG TUNE-SLIGHTLY INCREASEING INVERSE TQ TABLES.hpt22-12-11 12-47-00.hpl
    Jan 2015
    565
    Hello amd welcome. It seems you may be asking more from the turbo than it can actually provide. Also your data log resolution is poor from the sheer amount of channels that you are logging. You have a little duty cycle left it looks like but this may be from resolution gaps. I would take away all mapped points and see if recover enough resolution to see why your boost is falling to a less than desired amount. Many factors contribute to this so it can be a trial and error situation until you build what you actually need. Going to look through your tune now
    Jan 2015
    565
    I would set your torque tables and inverse tables back to stock and start bumping up your driver demand table. Ask for more torque in other words instead of a higher load for the same torque. Thats what I would do
    Feb 2018
    824
    Quote Originally Posted by reubone View Post
    thanks for the recommendation, but I've already tried increase the DD tables with no luck. That was actually the first thing i did after increasing the various limiters. All it did was increase the desired load, but the actual load stayed relatively the same. Maybe you are right in that i'm maxing out the turbo. Seems like a lot of tuned focus STs that I've seen are able to hit higher airloads than me and we have the same engine (to my knowledge).
    Jan 2015
    565
    Lets get a data log with only what is needed to diagnose airflow and go from there. With more resolution we may see the issue.
    escape.Channels.xml
    Try that and get us some data
    Jan 2015
    565
    escape.hpt
    This is where I would have started. Just for instance
    Feb 2018
    824
    escape.Channels.xml
    sounds good..i'll try that out and get back to you. thanks
