Results 1 to 6 of 6
Thread: 2000 Chevy 1500 4.3 Turbo
    Dec 2022
    3
    Stock 4.3 with turbo kit not wanting to upgrade to marine manifold because I don?t want too much money invested in this build it?s all eBay turbo parts hot side was fabricated by myself wanting to do a maf tune because I don?t have speed density os options. I need some tips or some tunes to get me started because I don?t know what the hell im doing? and any other tunes I can do to get more hp out of this truck
    Dec 2019
    MS
    567
    HP will be limited to fuel flow.
    Do you have a wideband?
    Also its hard to help without seeing your tune.
    Dec 2022
    3
    here is the stock tune and no wideband at the moment
    13,564
    Major bummer that it's a vortec computer and not a P01 controller, so much more you can do with the newer computer.
    What are you doing for fueling?
    Dec 2022
    3
    Stock injectors installing a quantum fuel pump would have to change intake for new injectors and not doing that right now so I need to tune my maf instead of speed density what’s the best route
    Feb 2009
    GA
    117
    Should install larger injectors. You could run out of injector with very little boost. Aus injection sells bigger injectors for the vortec 4.3 stock manifolds.
