Results 1 to 3 of 3
Thread: Air intake temp sensor calibration 2013 Challenegr RT 5.7
    Tuner in Training biggmac4's Avatar
    Nov 2012
    31
    Hi
    How do you recalibrate an aftermarket AIT sensor. I had to relocate and buy a screw in type to put in a welded bung on the supercharger piping. As of now on a cold start its pegged at 122 deg F.
    This is what I have . https://www.summitracing.com/parts/diy-iatwpiggy
    DIYAutoTune IATwPiggy - Summit Racing Equipment
    Sensor reads7,000 ohms at 48 degrees F, 1,930 ohms at 87 degrees F and 560 ohms at 146 degrees F. Includes a 6 in. long wire pigtail.
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    I thought it was 86f = 3400 or 3600 ohms
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
    Apr 2014
    704
    Quote Originally Posted by biggmac4 View Post
    Hi
    Safe yourself the hassle and get an IAT sensor for a 2000 Jeep Cherokee 4.0L.
    It's threaded and should have the same connector as you need (assuming the connector is the same on your vehicle as the 2006-2010 SRT vehicles).
