00 mustang gt cold start question
which table do i need to add fuel to get my car to start in 20 ish degree weather? should i work with the main ve table first or the cold start first. The car has been dohc swapped and has the ford 47lb injectors.
Latest update, I have added fuel to the ve table, the cold start, and even changed the stoic to 13.8. Nothing I do will get the a/f ratio below 14.5. What am I missing? I have even turned off the maf sensor and tried to run speed density with .7 lambada still nothing. I'm changing everything one at a time and loading the tune and trying to start the car.
Well, you need to tune the MAF table..
No idea what the hell your doing as there is no VE table nor can you turn off the maf
Theres at least 6 different fuel tables half of which will allow you to add startup enrichment. Simply command a richer lambda.
