Originally Posted by
engineermike
That's great power at that boost level, but why is it tanking above 6500 rpm?
The GDI pressure is lagging in the middle and up top the blend isn't increasing as more flow is available. You can command 90% blend and then use max injection angle to preserve mid-range pressure. This would cut the blend in the middle to below 70% but then allow 75 or more up top.
The knock data scares me a bit. If it's real knock I would be limiting the timing to values that result in little or no knock reductions. It seems like the timing is a bit low at that load, especially with meth, but it could be normal for a turbo setup.
On the cylinder knock retard, that is the retard applied to just that cylinder. Though, your SDLF is set to 3, which I don't know what causes. I only have experience using 0 and 4. Stock and Whipple use 4 at high rpm, while Roush and other Fords use 0.
On another note, your cam timing isn't really cooperating. It's not switching to OP until 4000 rpm which is probably slowing spool up. There are various things that could cause this, but one thing that can be done that helps other things also, is to have the highest load row of the Drivability cam timing to match OP. That way even if it doesn't switch to OP it still uses the right cam timing.
