Thread: Need base map!!!!
    Dec 2022
    Need base map!!!!
    Need a base map for 98 camaro ls1, 102mm throttle body, sheet metal intake. texas speed cam, 76mm turbo, 80 lb injectors. car is already tuned on full exhaust, 102mm, cam, intake and stock injectors. just added turbo, and 80 lb injectors. just need a base to start it and haul it to the tuner
    13,576
    Would help if you provided the tune file, can't really help without it.
    And you need to post what 2 bar MAP sensor you are going to be running and EXACTLY what 80lb/hr injectors they are.
    Any good injector brand would have come with the injector data that you can just plug right into the calibration. If they are some china knock off or no name injectors, good luck trying to tune with them.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Why not have your tuner send you a base map. Or like 5fdp said, if you bought quality pieces they shouldhave came with plug and play data to enter
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    565
    if you still need help,, email me at
    [email protected]
