Results 1 to 7 of 7
Thread: Trans Spark torque management.. I'm lost
    Feb 2019
    Indiana
    135
    Working on my turbo ls truck.. Have tried a few different things and Spark torque management keeps popping up and saying trans, when I am starting to roll into boost.. All the trans torque limits are disabled to my knowledge.. Can feel the spark dropping in the truck.. Not sure what else to do.. Any help is appreciated!
    7875 turbo, 80lb dekas, 4l80e swapped
    new exhaust2.hpt
    New exhaust2.hpl
    Try disabling [ECM] 321 under torque management.
    Feb 2019
    Indiana
    135
    Ok I'll give that a shot when I get home!
    Feb 2019
    Indiana
    135
    Quote Originally Posted by Mr.z0611 View Post
    all TM disable. Still pulling timing.hpl Still pulling timing.. its about time for a standalone haha
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    Try setting your min spark base timing 12701 to like -10* across all your cells where you have -20* and that should help. Or you could set it all at like 5* and it shouldn't pull timing below that value. And you want your max torque 2869 to be what your actual max torque is or a little above to the crank.
    Jan 2019
    Australia
    81
    Under Torque Management - Trans Input Max - Set to 8,192 Nm & set Spark Reduction to Disable
    Feb 2019
    Indiana
    135
    Thanks guys, the abuse mode was the issue.. Set that back to stock and it runs great now
