Hey
Just installed a 3 bar map with 60lbs injectors and its now cutting out around 2,500rpm. I did notice once the MAP Kpa goes over 100 this happens. What am i missing?
The car is a 2013 R/T 5.7 with a Torqstorm supercharger.
Hey
Heres the injector data.......
Mopar 3 bar MAP sensor (5149056AA)
Enable sensed MAP and see what happens.
2018 Trackhawk PCM/TCM tune by Dusterhoff.
Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
Problem solved. It was injector data put in wrong. Car runs great now.
Thank for the update
04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
G3 Hemi Videos
https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
can i get a file from you i just installed a gen v whipple on a 6.4 with 3 bar map and hellcat injectors from whipple which im guessing are 60lb injectors.
