Hey guys I haven't posted here in a long time but I have a problem I just can't seem to figure out. I have tuned many gm vehicles from nitrous to cam only to supercharged and turbocharged and they all have started and ran fine. I finished this truck a couple months ago and it's a monster it does 4wd burnouts until you let out and rolling 70+mph 2wd burnouts. The ve and timing are dialed in and it runs perfect. However I'm having a startup issue. The truck does not like to start for some reason. Anyways here's a rundown of the truck and what I have tried so far.
Truck info
1999 Silverado 5.3/4l80 4wd manual tcase p59 dbc ecm swap with 3 bar OS and flex content sensor working.
10:1 5.3
Tbss intake
G-plus 92mm dbc throttle body (eBay)
Ported 706 heads
Elgin e-1840p cam
7875 1.25ar vs turbo
88lb injectors (flow matched oem decaps)
My buddy has a suburban that is very similar other than 9.5:1 a e-1838 cam and p01 ecu that I tuned and it works wonderfully that's what has me puzzled.
What I have tried
1. Raf was dialed in
2. Iac vs effective area was tuned using a user math to match idle desired and dynamic airflow
3. I've added a ton of startup airflow and taken a ton away both show no change
4. I've modified the cranking ve up and down with no change
5. I've modified the cranking fuel FA mult table values up and down a little at a time until they where double and then they where half no effect.
I notice that when I start the truck if I give it gas pedal and allow air in it will start up but I have to help it for a second sometimes. Once it starts its gold. When I do a datalog and try to start it the desired airflow is really high and the stit go way high. I've also noticed an inconsistent iac counts. Sometimes I start it and at 72? with an ambient temp the counts are at 50-60 then I can kill it come back later and they are at 120-125 with the same afr and ambient temp reported. Both datalogs taken the same day. I thought it could be the cheap eBay TB iac is too small so I ported it to death redid my raf and effective area it gained some flow on the effective area chart before counts where maxed but still doesn't want to start. I then opened the throttle body up to where the iac counts at operating temp are 0 and the stit goes way - so I disabled the - ltit learning and it will start that way. Basically the engine is wanting a ridiculous amount of air to start up and idk why. My mind says it has too much fuel at startup but I've modified that so far down theres no way it was getting too much fuel. I'm at the point I think it may be an issue with the ecm or something else.
