Results 1 to 15 of 15
Thread: CTSV going really rich at P/T load
    Dec 2014
    46
    My 2011 V is just a simple bolt on setup. 2.5/8.6, Kooks LTs offroad C, Airaid, DMS Heat Exchanger CWA pump, DSX Aux pump. Here is my file and log, Im in the process of tuning Part Throttle, But noticed my EQ dips to like .62 on a light load.
    Thanks for any suggestions
    Feb 2018
    830
    Quote Originally Posted by lsxjunkie View Post
    You most likely just need to re-adjust your maf curve considering you are running a maf only tune. It's dipping that rich when you are in Power enrichement (aka Open Loop) so you are no longer getting 02 sensor feedback. Who tuned you car?
    Dec 2014
    46
    Quote Originally Posted by sgod1100 View Post
    It was originally tuned by a local shop, prior to adding the Longtubes and aux pump. Yea i figured it was a MAF Freq issue. but it wasnt showing to trigger PE mode even tho is was past the KPA trigger for it. But it was such a drastic dive that i didnt think the MAF curve was that far off. Was wondering if the FPCM settings werent causing the issue.
    2,751
    This looks to me like the MAF just needs to be retuned. I always recommend VVE tuning also to go along with that. I know it is bolt on only but the changes are pretty drastic with mods.
    I'll warn you that several times fuel pressure is on the high side.. It is doing a decent job following commanded fuel pressure. It is common for injectors to misfire or stop firing all together somewhere north of 80 psi.
    Tuner at PCMofnc.com
    Dec 2014
    46
    Ill start scaling the MAF freq. based off EQ error then. Thanks for the reply. The FPCM settings for low/high command look ok? I was trying to find the PID for pump duty cycle, etc. I think I have a good list of PIDS currently.
    I agree tho, I will tune the VVE table and look into their zones as well soon.
    Feb 2018
    830
    Every time it went extremely rich your commanded went to 11.9 so that tells me you are now in PE. But yeah, adjust the maf curve and you should be good to go. FYI, on my ctsv I have VVE enabled up to about 3200 rpm. I've read that this helps with driveability of the car especially when cammed. Maybe that's something you should look into doing (tuning VVE). Honestly I've had my car on blended and maf only and I couldn't really tell a difference. Only reason I tuned my VVE was i am planning on camming my car in the future and wanted to get use to the process
    Dec 2014
    46
    Yea I agree on the commanded changing to 11.9 and then being in PE. Not sure why the PID doesnt reflect that. My tune has PE enable at 105kpa. I will go back and turn on VVE and turn it off commanded and er error. Going to tune some this evening. It was raining last night.
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    Log Fuel Trim Cell and you can see when you go into PE.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Dec 2014
    46
    Im making progress.... But I couldnt stand it and did a WOT hit. DAMNNN felt good and the fueling looks dead on. Where is the PE/COT Advance table? looks like it is adding to the base. but 22* seems like its ok on E70.
    What is causing the cold crank fueling to be so rich? EQ command is like in the low .80s. Also im doing this MAF tuning FWIW with short term closed loop on.... Is this going to be an issue?
    Thanks for the help guys.
    Mar 2015
    233
    You have 3.5 degrees of timing in the alcohol table. Thats PE/COT, put your mouse over it and read the bottom. I have the exact same setup on my V and I add all my FF timing in the FF table. Also I prefer the multi vs comp to be more linear, but whatever works for you...
    I recently had an overly rich cold idle, which resulted in surging. I turned off all fuel modifiers (including o2 readiness, yours is still on), and retuned the maf. Problem is gone.
    Even with 70 psi, you are out of fuel injector.
    Your flex fuel table has positive values on the top. You should be running less timing at lighter loads on E. Shoot me your email address and ill send you my tune. you can compare some stuff.
    2011 Camaro SS
    Thompson Motorsports Dart 427
    ESS Tuning G4 Supercharger 1158whp/1017wtq
    DSX Tuning stuff
    Feb 2018
    830
    Quote Originally Posted by justhereforinfo View Post
    Would you mind sharing your tune with me? I'm probably going to be going FF in the future and like to have something to reference. [email protected]
    In my opinion 2300 rpm cut off works better for cammed V, since our VVE table typically develops that stupid "ridge" right around the 2400rpm mark.
    Also Lambda is superior to AFR.
    On some e67/V LTFTs will mess up/start making your tune extremely rich in about a week, specially if you have meth injection. Not sure if this applies to the OP.
    Feb 2018
    830
    Quote Originally Posted by mememe123 View Post
    that ridge you are referring to is about 2600 rpm for my car (stock cam)...I was told by people smarter than me that it's reversion
    Dec 2014
    46
    Do you still use dynamic fueling then up until 2600? And does it have an transient issue switching between dynamic and MAF only at that rpm?
    Feb 2018
    830
    Yes, i think mine is cut-off at 3000 rpm (haven't looked at my tune in a while). I have tried EVERYTHING that I know to try and get rid of it and I haven't been able to. I'm thinking it may be able to be fixed by manipulating the prediction coefficients, but I'm not smart enough to know how to properly do that. No transient issue that I'm aware of. I noticed it after removing my stock LSA injectors for some I.D. 850s. One I did do to help with the lean condition is I slowed down my 02 sensor switching...that seems to help a good amount. With my car being an m6 I can actually feel a slight lean surge when passing through that 2600 rpm area
