Results 1 to 5 of 5
Thread: p59 throttle area max?
    May 2019
    new england
    74
    does anyone know the maximum you can adjust this table?
    I cut down my pedal length to fit my application and its very touchy part throttle.
    option 2 should i go about it through torque management?
    option 3 would be spend more time trying to fit the stock length pedal.
    Jan 2014
    SoCal
    1,565
    Not recommended to mess with the throttle tables. Bad stuff can happen. I would personally fit the stock length pedal
    Nov 2006
    2,745
    Maybe a pedal commander might work.. I think they have options to make the pedal less sensitive
    Tuner at PCMofnc.com
    Aug 2016
    Swansea Wales UK
    186
    When i chopped down the adjustable pedal arrangement that came with the engine i had similar problems riding over bumps in the road. An extra spring on the pedal worked and it wasn't tiring on long journeys
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
    Mar 2011
    Ripley, MS
    1,865
    I don't think they offer one for a P59 application. I looked at a few brands and didn't find anything available.
