Results 1 to 14 of 14
Thread: 2007 tahoe truck norris check engine light
    Dec 2022
    5
    I have a 2007 Tahoe 5.3 that we did a dod delete and installed a BTR truck norris cam. I accidentally saved over my stock tune, I now have a P0606 code that comes on and the truck goes into limp mode. I have raised the idle rpm and changed the air settings at idle. I would appreciate any help with this thanks
    7,619
    'Base' should be the file from the last time you downloaded the tune from the ECM. Open in new editor, then save with a new name.
    Dec 2022
    5
    i saved the changes i made over the last one i read, now the ecm is unhappy with number i have somewhere i suspect
    Jan 2014
    SoCal
    1,562
    I did not know that. Had to check it out myself. Thanks Squirrel.
    Aug 2009
    Calibrating
    3,373
    Electronic throttle settings most likely
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    7,619
    Quote Originally Posted by Julian1948283 View Post
    Are you not able to see my post or something?
    Dec 2022
    5
    I saw your post but mine is blank, there is nothing there
    7,619
    Then this statement is untrue:
    If you'd read the file out of the PCM, saved it, made a change and saved that, then the history would show the previous version, or however many previous versions back to the last time you read and saved the file straight out of the PCM.
    If your changelog is blank, that means the only file you have has had no changes since the last time you read the PCM. Which is not what you said happened.
    Dec 2022
    5
    Thanks Blind squirrel. I got the P0606 to clear by putting the stock tune back in. I have an issue where the vehicle will crank but not start unless you press the gas pedal about 1/4 of the way down. I was also wondering if there is a way to increase the misfire monitoring. Any help would be greatly appreciated.
    7,619
    Trying to follow a Gen 3 idle tuning guide on a Gen 4 E38 (he posted in the wrong section) is unlikely to lead to anything good.
    Dec 2022
    5
    do you have any links to follow?
