Results 1 to 13 of 13
Thread: E38/T42 combo issue
    E38/T42 combo issue
    Hey everyone. Had a customer bring in an old suburban running a L94 engine with a LSA blower with L94 tb, LS3 slot maf, Corvette throttle pedal, T42 TCM with a 4l80 trans. The calibration it was flashed with was an express van from 2009. Issue is the second you go WOT goes to limp mode p0600 code so it's a TAC calibration issue. What car/truck OS will work for this combo?
    Aug 2009
    Calibrating
    3,373
    09 express van works fine, it’s also 80e
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    7,649
    Are ALL '09 Express vans the late 127lb OS, or did they split 2009 into early/late like some other platforms did? I have several '09 Express sample files and they're all late versions, but that doesn't mean there weren't early ones that I just haven't seen.
    So what would cause the limp mode p0606 code. The Corvette APP works with that calibration? That's what it is, but the second you give it any serious throttle the P0606 code comes up.
    TB data is stock for express van. This os is a 127lb
    Jan 2014
    SoCal
    1,565
    Corvette pedal, E van TB and OS. These questions are common and it seems to me that all must match exactly. Try a E van pedal
    7,649
    Is it the right ECM service number for the OS, and was it initially programmed properly using the right tools (meaning, not HPT)?
    There are lots of things that could be ruled out with more information, but since there's no tune + log posted yet, maybe it will forever remain a mystery. <shrug>
    Aug 2009
    Calibrating
    3,373
    Someone monkeyed around with the OS I bet…
    14 Gen 5 Viper
    Programmed by PSI originally. 12630501 is the OS that's being used. I don't have a tech2 to try to reprogram it.
    so try to have it reflash with a tech2 with the same OS?
    Nov 2017
    1,466
    Quote Originally Posted by Stangguy View Post
    Post the current tune so the experts can help more (see post 7).
    7,649
    Need a log more than anything else really, since that's the only way in HPT to see all 8 segment IDs (the tune file only shows 6, does not include the 2 for ETC).
    1972 suburban - Jason - stock.hpt
    Stock file supplied
    I don't have the truck here at the moment for a log.
