Results 1 to 13 of 13
Thread: Ok got an odd one here, 12V cummins swapped 09 F-350 6.4
    Jul 2022
    34
    All right guys I've got an odd one here. Got a customer with an 09 F-350 originally 6.4 diesel that has swapped in a 12v cummins. I plugged into it to read the ECM but all I can see is the TCM. I was able read and save the file but when I open the file it only shows transmission data. Would this be due to a missing ground on the ECM? Any help would be appreciated.
    Jul 2022
    34
    transmission data only, the only engine data i see is PTO.
    Advanced Tuner JaegerWrenching's Avatar
    Jun 2018
    Albuquerque New Mexico
    467
    It's not seeing the ECM so you have to find out why that is.
    Jul 2022
    34
    Quote Originally Posted by JaegerWrenching View Post
    Really?
    Jun 2018
    467
    Quote Originally Posted by NorthernEdge View Post
    Really?
    Really!
    Jun 2018
    467
    Look for this ground top right of diagram. ECM Ground distribution.png You obviously need power and ground for the ECM and to have power and communication on your OBDII connector.OBDII.png
    Banned
    Jan 2020
    Arlington WA
    250
    DRIVERSIDE under degas bottle you have 3 connections.. 1 big black plug, 1 big white plug and 1 small black plug. the 2 big connections can be a pain sometimes and if not plugged in correctly it will not communicate to pcm. check those connections.
    Oct 2018
    baxter mn
    11
    is this a real question? can you find the ecm?
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    474
    if it has a Cummins engine why would you need the 6.4 ecm side of the tune? or even need to see the data from the ecm side of it?
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    May 2011
    38
    12v cummins wont have an ecm. nice trolling....
    Jul 2022
    34
    I got it to where I can read the ecm and tcm all that is good. Disabled pats in the ecm and wrote entire. New problem is it isnt engaging the starter. All the cummins needs is a reference from the ecm like a signal to start and then it doesnt need the ecm after that.
    Jun 2018
    467
    Does it have power on the starter solenoid wire when cranking? How do you have the truck wired for the starter?
    Jul 2023
    1
    One thing i ran into on mine was if the Ford ECM didn't think the ford fuel pump had power it wouldn't send power to the starter. realized this when i left the relay out for the ford fuel pump when testing some stuff.
