Results 1 to 2 of 2
Thread: Engine stuttering
    Jan 2020
    11
    Engine stuttering
    For the last couple of days, I have been getting random engine stuttering (Chevy HHR 2008 LT 2.4 manual, 100'000 miles). When this issue occurs, stepping on the throttle sometimes doesn't seem to trigger a response and then one or two seconds later, the engine responds, but sluggishly. The car then feels as if it had no power.
    CEL light doesn't light up, but I sometimes get these two engine codes:
    P171: System too lean
    P300: cylinder misfire
    When stepping out of the car after the stuttering has occured, there is quite a pronounced fuel smell (not gasoline smell per se, but the kind of smell you get with bad combustion).
    In the attached log file, the stuttering starts at about 08:24 until the end of the log. Is there anything in the log which could indicate the cause of the stuttering?2224.Channels.xml2224.Layout.xmlstutter.hpl
    Jan 2014
    SoCal
    1,565
    Do your diagnostic. You have codes. Check them out. Could have a fuel pump failing given you have a P0171 and P0300. Could be a bad coil/plug. When was it tuned up last. Don't start with tune issues until you have mechanical issues solved.
    Freeze Frame data is your friend.
