I have C7 Z06 and I can't see Idle adaptive spark control under Spark/ advance in my HP Tuners Ver 4.12
I need your help guys.
There is no adaptive idle spark table. These cars are torque based and use torque calculations to determine whether to add/remove spark or throttle angle and when/how to adjust the idle.
AND to add to that - don't think you can just adjust the 3 idle spark tables as I'm sure you'll find them and be good to go as these are the "floor" settings for how much torque will allow timing to drop at idle and by raising them up to where "you" want the timing will cause all sorts of idle issues. The only way to get idle timing right is to dial everything in fueling and air modeling related and then adjust the idle settings and then torque model....
~Greg Huggins~
Thank you very much guys for this valuable information,
I will keep in mind all this.
