Results 1 to 2 of 2
Thread: VCM Editor - Flowchart of tables
    I'm enjoying watching all the videos and reading up on the tuning through HP tuners. Having only used Haltech, this is quite different.
    One thing I still haven't found is a good overview of each of the tables and how they work, and how all the values are added/multiplied before they end up at the engine.
    For example, we have our base spark map, then we apply the AFR correction additions/multipliers, then we apply the IAT corrections to the result of the AFR correction, etc.
    Essentially I want to know the process of how the final value is calculated starting from the base tables.
    Where is all that valuable information hiding?
    Thanks!
    Nov 2017
    1,464
    Only available by digging through the forums if available at all or by experimenting. There are can be MANY other tables that aren't defined by HPT on some platforms.
