Results 1 to 2 of 2
Thread: 2011 ford f150 5.0 cams zero out after shift.....
    Advanced Tuner 68Camaro's Avatar
    Mar 2011
    Van Buren, AR
    326
    after shift cams zero out for about 1 second before moving back to optimum power with about 60ft/lb torque loss....
    have made several changes but haven't found solution...
    hoping someone can chime in that has found solution to this problemCHARLEY PARRISH 2011 F150 STREET PULL CAMS ZERO AFTER SHIFT.hplCHARLEY PARRISH 2011 F150 5.0 JP TUNE.hpt
    Jun 2020
    788
    Not sure why it's doing that but you should be able to add desired and actual cam position for all 4, all 4 solenoid duty cycles, and the VCT schedule mode to the log which will help in diagnosis. My guess is that the mode is going to "VCT disabled", but you'd want to confirm.
