Results 1 to 9 of 9
Thread: 6L80 Hard Shift Issue After WOT
    May 2008
    Wichita, Kansas
    147
    2011 Avalanche, 5.3, 6L80, ALL stock, stock tune, 180k miles. After going WOT and letting off the gas the trans will slam hard into 4th, then 5th, then 6th (depending on speed, shifts are about 1-2 seconds apart from each other). Is there something I can adjust in the tune file? It downshifts into the correct gear going WOT without any issues, just slams into gear during the upshift after WOT only.
    2015 Yukon SLT 5.3
    2,737
    I'd scan it for codes when it starts shifting hard.
    Tuner at PCMofnc.com
    May 2008
    Wichita, Kansas
    147
    Zero codes. Trans shifts excellent otherwise.
    7,619
    I know why the T42/4-speeds do this - run it up just before it would make a WOT shift, lift off, and it looks at the part-throttle shift table and immediately upshifts, but RPM is still high and delivered torque is low, so it doesn't pull any timing and it shifts much harder than if you'd stayed in the throttle. The 6-speed stuff is doing things much differently though, but the conditions to make it happen are the same I guess.
    Waldorf MD
    774
    A copy of the tune file would be nice...
    Daily Driver= 2003 BMW 330xi
    May 2008
    Wichita, Kansas
    147
    Quote Originally Posted by jaydubb71 View Post
    Stock tune, no changes
    2015 Yukon SLT 5.3
    Oct 2014
    Moscow, Russia
    197
    Do you feel delayed Drive/Reverse engagement from Park/Neutral?
    May be it's time to inspect pressure switches is the TCM.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    May 2008
    Wichita, Kansas
    147
    Quote Originally Posted by verlon View Post
    I thought about that, but zero issues with engagement both hot and cold.
    2015 Yukon SLT 5.3
    Oct 2014
    Moscow, Russia
    197
    Quote Originally Posted by Ls1c5vette View Post
    Can you record a log with all PCS pressures @ high sampling rate? Prolonged air purge phase may indicate fault of the corresponding pressure switch.
