Hey all - complete newbie I admit - however other than the write up from Metroplex several years back and changes in the Editor since his write up - has anyone continued providing support for the SHO Ecoboost. It varies based on engine - transmission and design from the different versions of changes Ford did not only to the Taurus engine in 2015 - but differences in exhaust and design for the F150's differ. Doesn't seem safe to try and use anything from the F150 threads.
I am trying to update for my own records the Ecoboost recommendations Metroplex documented. However I am missing certain key places in the Editor from the write up like the IPC - MAP Maximum. It obviously moved - however I cant seem to find the place it went too. Is there anyone else that is out there that can share their files - all I am starting with is stock - and TBH the "Tune Repository" is lacking even a 2014 SHO Stock file. Doesn't seem to be a place to submit one - even if it could be used for others.
If these forums are not the place to go for help - any suggestions?
Kryptto
