Torque converter recommendations
Anyone have any torque converters they recommend? Just swapped to a stage 2 vvt cam... It recommended a 2800+ rpm with the kit I got.... Just wasn't sure about brands or what was recommended for daily driving... I don't mind a little hp loss for drive ability...
Here's what is have
TSP Stage 2 VVT L99 Cam Specs: 227/239, .629"/.629", 113 LSA
Call up FTI I have one of their 6 disk converters in my GTO
I've had good luck with PATC in Louisiana. they have a decent website (although not the greatest to navigate, but very informative)
I've bought a couple of transmissions and several diff styles of TC's from them over the years.
I use CircleD 99% of the time. and no issues or regrets.
I put a Circle D in my 6L80 rebuild and I love it.
3600 Single Disk Circle D for me too in my 170k mile + 6l80
Circle-D 2,800 stall single clutch converter.
Why do I say 'single clutch'? ... Because the only reason you would need a triple clutch converter is if you plan on locking the converter at WOT. And for a car that is not a purpose built drag race car, there is no reason at all that you would ever need to lock the converter at WOT.
BTW ... the stock C6 Corvette converter is right at 1,700 rpm stall ... a 2,800 stall is a very big jump from that.
Going too high on the stall speed will only hurt the overall 'drivability' of the car ... A 2,800 - 3,200 stall converter will launch the car real good!
I only use the triple disk in the turbo trucks that tow. Everything else gets a single disk.
