Results 1 to 8 of 8
Thread: Tune improvemnet help
    Dec 2020
    Tampa
    47
    Asking if one of the tuning experts would take a look at my scan to see if any improvements can be made.. Thanks in advance.
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    Hello friend, do you want to see if the car can improve even more? surely yes
    I am seeing that it can improve much more, send me a message to my whatsapp that is below and we will talk better but if it improves a lot, it lacks more power
    ?+58 4149648393
    [ATTACH=CONFIG]127783[/ATTACH,
    Nov 2009
    All Around
    3,149
    alot of power to be had for sure.
    Oct 2021
    Allentown PA
    363
    Quote Originally Posted by tkemp View Post
    Post up the tune, and we can look at it.
    Fuel trims look good,
    No Knock Voltage being logged, Need to log it, need to know how it's reacting to timing and engine load.
    No VE being logged, no air flow.
    Also it's runs hot, do yourself a favor , before you lay out any money to get a "better tune"............ get a 180 degree thermostat.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Dec 2020
    Tampa
    47
    Latest Tune file... any help or advice is greatly appreciated.
    Tuner in Training evildodge's Avatar
    Jun 2021
    Texas
    35
    Pretty sure its running lean and seeing lots of knock on wot pulls, thats why spark is barley topping 7 degrees about 5200 5600 rpm and pratio and aircharge numbers look low
    Just my 2 cents
    definitly log st and lt knock and fa ratio and post another log
    Dec 2020
    Tampa
    47
    Thanks Rays04/// 180 thremo is on order.
    You need to add a few things to your scanner channel.
    Aircharge
    Volume Metric Effeciency
    knock sensor voltage 1 & 2
    Spark Knock
