Results 1 to 5 of 5
Thread: Reading PCM that has been modified usning TunerPro
    Feb 2017
    Houston Texas
    67
    Hello, I am going to tune a vehicle that has been modified using TunerPro. When I pull the calibration from the PCM will the modified file be downloaded or will a stock file be downloaded that matches the PCM. Thank you in advanced.
    Advanced Tuner N2speed's Avatar
    Mar 2021
    Pompano Beach FL
    261
    It will read what ever is already there.
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Jun 2007
    Finland, Europe
    549
    As long as it's not Virtual Read.
    https://forum.hptuners.com/showthrea...read-questions
    For OP: which car/engine?
    Feb 2017
    Houston Texas
    67
    Quote Originally Posted by Pekka_Perkeles View Post
    Thanks for the link. I will read through the thread. The vehicle is a 1995 Chevy Silverado running the original L31 engine. The owner swapped in a 0411 pcm and loaded a 2002 express van tune file using TunerPro.
    I was interested to know what file would be pulled so I know if I need to pay for credits for whatever file HPTuners will pull and to unlock an express van tune.
    Jan 2014
    SoCal
    1,562
    If you want to write a file modified from whatever you read using HPtuners it will cost you credits. You can find a stock express tune file and do a compare Ctrl+5 compare log and see what HPtuners see's as different as along as the OS's are the same. Some areas that TunerPro can modify will not show in HPtuners so you won't know.
    Your choices.
    1. Run what you got if it works.
    2. Modify what you got until it works but know that if a PCM fails you lost whatever may have been on it.
    3. Flash it with SPS/Techline Connect to a factory setting for the Express van and start fresh but realize you will not be able to modify it the way TunerPro can.
