Results 1 to 6 of 6
Thread: Supercharged 2013 Jeep SRT8 MAP limit?
    Is there a hard coded limit we cant go past on these cars? I seem to be hitting a cut right at 200kpa.
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    hello, good evening no amgio you have map reading limiters The map is limiting you to more PSI check those maps
    EMAIL: [email protected]
    WHATSAPP: +58 4149648393
    INSTAGRAM: @quickxsteplogo quickstep.png
    7,647
    Quote Originally Posted by Josue Galban View Post
    WHATSAPP: +58 4149658393
    INSTAGRAM: @quickxstoplogo quickstep.png
    You really, really need to stop doing that, my friend.
    It's been my experience that the Dodge GPEC2 ECU doesn't read boost about 14 psi (roughly 200 kpa). so you have to do some scaling trickery. I haven't completely figured it out yet, but I'm working with someone to get it ironed out.
    Jun 2010
    293
    Go to :
    ENGINE DIAG-------------AIRFLOW--------------------MAXMAP(45635)---------------set to 195kpa
    this will prevent the map to read higher than 200kpa and will avoid the limiter.
    how much boost you shooting for? you should be ok at 15-17 psi fueling wise, more than that and probably you will have to scale the map sensor the old way or something like that.
    Jan 2022
    1
    hi Josue I have a tuning job for U 2012 Jeep Grand Cherokee ASAP I'm an engine builder need help with hp tuner vcm edit contact me what's ap +590690383432
