Quick question for the forum. I am currently running a 1 bar MAP with MAF tune in my 07 C6Z06 twin turbo. Everything is tuned well with current setup including VVE, timing, PE, etc. Up through 105kpa.
Thinking of moving to a LS9 3 bar MAP for improved reolution especially for AFR's in the scanner under boost. My question is, if I stay MAF tune but refine the VVE, timing, and PE tables for the boost, areas.can I start the process by coping the 105kpa lines into the new boost areas and work from there? Is that how the 1 bar MAP tune interpolates it now?
Thanks for your help.
