Results 1 to 13 of 13
Thread: Help Please!!!!
    Jan 2023
    5
    Help Please!!!!
    I have a 2005 GMC Sierra that I swapped the original 5.3 for a 6.0. I also had a Brian Tooley Truck Norris cam installed with Speed Engineering long tube headers and Y-pipe, I am having the problem with the truck idling. It will not stay crank parked or when I come to a stop. I am a newbie, as this is my first attempt at tuning. I value and appreciate any advice please help.
    13,565
    Who set the idle speed to zero for park/neutral?
    You need to change the cylinder volume for the 6.0. Copy over a 6.0 VE table. Add some base running airflow because of the camshaft.
    That should get it to run better. Lots of other changes to timing and things like that will be needed.
    Will want larger fuel injectors too, a 6.0 with a camshaft will max the stock injectors at full throttle.
    Jan 2023
    5
    Thank You
    Sep 2009
    764
    GM set the idle speed to 0 on manual transmission stuff. I personally segment swap a matching year/operating system 6.0L stock engine and engine diagnostic segment into engine swaps. Much of the code and many tables that cannot be viewed with HP Tuners are different between the various LS engines. The vehicle will run better if you start with the correct calibration for the engine to start with.
    13,565
    I am well aware of that. His tune file shows it's running an automatic still.
    Jan 2023
    5
    This is the tune that I have now, and I'm still having the same problem with the truck shutting off when I put it in gear. Help please!Ghost (running).hpt
    13,565
    What injectors did you install?
    The only thing changed in that tune file is the injector flow rate, so you are missing the rest of the injector data.
    Cylinder volume needs to be .74954 I believe for a 6.0.
    Lower the idle spark advance to around 20 degrees. Decrease the over/underspeed spark correction tables to roughly +/- 8 degrees.
    Return the MAF curve to stock to start over.
    Jan 2023
    5
    Still the stock injectors
    13,565
    Put the flow rate back to stock then, you change it to injectors that are 40 something lb/hr.
    Stock injectors are 25lb/hr.
    Jan 2023
    5
    Ghost stock idle adjust.hptIdle.hpl
    Here is the stock tune with idle adjustment. Shuts off on decline of rev.
    13,565
    If I could view the data logs I'd maybe be able to help more, I'm using an older version of the software and it doesn't let me.
    I don't see any glaring problems with the tune itself so the data log is the key to figuring it out. Look at fuel trims and what some of the sensors are saying and check for codes.
    MAP should read roughly 100kpa key on engine off. Fuel pressure should be roughly 55-58psi. Fuel trims should be around zero give or take +/-5, if they are super negative or super positive that would be a problem.
    Mar 2011
    Ripley, MS
    1,865
    There are several changes that need to be made for that cam. The VE table is still stock and needs to be dialed in. For now, go to table 3003 under the Airflow tab (High RPM disable) and drop it to 200 rpm.
    The big problem is the Base Running Airflow table is still stock. Based on your MAF reading at Idle, it will need to be nearly doubled. There are a lot of other changes required, but these two changes will get it to idle.
    Jan 2015
    Arizona
    439
    ....and nothing since
