Results 1 to 5 of 5
Thread: CTSV TCC Slip
    Dec 2014
    46
    CTSV TCC Slip
    Im seeing over 1500rpm of Trans Slip rpm when the trans commands the 3-4 shift attached log and editor file. Is this normal seems excessive and costing me some time and power.
    Just a bolt on car with E85.
    Can this be fixed in the TCC Pressure settings?
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    494
    Quote Originally Posted by lsxjunkie View Post
    (1) You are commanding the TCC to lock at WOT and (2) the desired slip tables are not zero'd out.
    Additionally, locking a (factory) single disk converter is not a good idea. It will ruin it and send bits into the transmission, then you gotta rebuild the trans and converter. I would suggest NOT locking at WOT for the safety of the car. It is slipping because it can't hold the power.
    405
    2,315
    Those are set to lock WOT on the stock calibrations all except 1st gear. As are many 6 speed stock calibrations.
    Aug 2009
    Calibrating
    3,373
    The 6l90e has a nice dual carbon clutch too.. very good converter
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    have you tried adding 40-60psi to the tcc and zero all tcc, set tcc gain to 1???
